1987 GN Hardtop For Sale
twstdv6
I have my 1987 GN for sale! I hate to do it but I lost my Job and I'm interested in starting a Business and working for myself at this Point!
The car itself looks good and drives good for a daily driver, But it does need a Paint job! I bought it I believe at 147k per carfax and have put less that 15k on it. Has new Suspension, Bilstein shocks and 2 1/2 inch new cat back exhaust and ATR Rear sway bar. Cross slotted front rotor and new front & rear brakes. The were done within the last 2yrs.
Has a rebuilt .20 over motor with less that 10k on it, does not smoke on startup or idle! rebuilt transmission with some perfomance mods with less then 7k on it, Stock Rods & Crank, Heads Studded and ARP Rod Bolts. Diamond Pistons with file to fit rings. Ported Heads w/new stainless valves and valve job, nice smooth street port, not a full race! Champion Intake w/70mm throttle body. 60lb hi-z injectors, 210/215 roller cam, T&D 1.55 roller rockers and comp cams roller lifters. new water pump, alternator, upgraded steering shaft, new power steering pump and Hydroboost system! SMC alky kit, CPT 66 Turbo, Stretched polished stock location intercooler, 4'' downpipe w/cat cut-out and a custom Cottons 4'' to stock 4 bolt Cat for emissions! Stock headers, precision vigilante 3200-3500 5 disk converter, new fuel pump and hotwire kit, billet FP regulator, 4'' Maf pipe w/4'' K&N filter, Tubular upper A-Arms, Drive shaft loop, new 3 or 4 core aluminum Radiator, 20'' rims, steering column lock, 2-way alarm w/ remote start, Has A Fast XFI w/data logger built in running speed density and I also have the origional computer and I'm sure alot of other stuff I left out and I have alot of the origional parts also! These are pics I had on computer, got snow here in Denver, will try and get more pics for those interested! Has water, oil and boost gauge, I also have a CyberDyne Digital Dash complete with sensor's that I was going to install this Spring! I also have a second motor, with stock unported heads, machine work done, just need assembly!
If you are interested or have questions, and want to speak with me directly, leave a message and i will give you my number, Thanks for the interest Members!
I am asking $15,000 OBO
looks great from a distance and close up, but it has a few scratches here and there, was like that when i bought it, the guy's kid and his handle bars, few scratches on door and rear quarter. and front road chips, the normal.
Doesnt look like it needs paint at all but I guess pics can be decieving. If so, paint is $6-8k. Car looks pretty nice to me. Maybe u should post some close ups cause for a driver it looks dam good. Has some nice parts to.
Howbout some interior and engine pics?
I'll try and snap a few from the Garage and post, snowing like crazy tho! but i'll post what I can, It's got a few dings & scratches, but i think most would let it go for awhile and be happy!
PIcs
I finally got a channce to pull it out the garage and snap a few pics, not the best pics, it was snow and cold out side!
More Pics
pics
