1987 Buick Regal Turbo T W02, 57k mi., hardtop (CT)
Trader history for Diggle (0)
Diggle
*** ESTATE SALE ***
15 minutes from Foxwoods
Price: $9000
Mileage: 57100
Owners: 2 known. Current owner (father) deceased and owned car since September 1993
Color: Light Sandstone Metallic (gold); cloth interior in saddle/tan
RPO Codes: Truck RPO image attached; description of codes available
Summary:
- Car spent life since '93 outside and uncovered.
- Only about 7k miles put on car since '93.
- Carfax report shows clean.
- Original/factory: engine, tranny, rear end, turbo, injectors, MAF sensor, intercooler, downpipe, plenum, valve covers
- Original owner had 3 TRs thru the years. Other T sold; GN keeping.
Body/exterior:
- Partially repainted in 2015. Hood, rear quarter only
- Light surface rust seen on:
- Under/inside both DS, PS doors.
- Trunk trim valence between rear window and truck had light surface rust under DS.
- Side window roof drain gutters
- Glass - no issues other than inside tinting bubbling
Interior:
- Rug has minor UV color loss but in great shape overall
- Seats clean, no tears or holes. Couple small, pinhead-sized marks in seats, possibly from cigarette ash
- Dash has a cracks on each end near speakers.
Engine and Enhancements since bought:
- Duel-muffler from cat-back: from Bowling Green Custom's; installed 1994.
- Kenne-Bell ram air kit; K&N 8" air filter; installed 1994.
- ECM aftermarket Chip: "RN" chip currently installed.
- Rear springs: from Goodyear; installed 2012.
- New, aftermarket Kenwood radio and speakers; installed local "radio" store in 2017. Original factory speakers and radio w/ equalizer included.
- MAF 3" pipe; Inlet pipe: black, powder coated aluminum; installed 1994
- Temporarily installed Scanmaster unit to troubleshoot. Scanmaster will NOT be sold with car. Results of numbers from starts and idles available.
Current known issues/needs:
- Rear lights/brake power master: Brakes/car stops fine, but brake pedal does not rebound fully after being pressed.
- Battery should be replaced.
- Headliner sagging and should be replaced.
- A/C needs charging.
- Window tinting is applied inside sticker vs actual dark tint. Tint bubbling and should be replaced. RPO code says it was factory ('A01').
- Weather stripping needs replacement.
Additional pictures and maintenance items available of undercarriage, engine, inside, outside if requested.
Have some receipts and some info in log book. Summarize in Excel sheet with date and mileage when noted.
Thanks,
dave
Contact: Email: dffontaine@gmail.com , or PM
Diggle
More pics...
Diggle
Just to update all that contacted me via email or PM, I'm contacting in order of when I was contacted.
Diggle
Car is under deposit. I had a lot of interest and wish I had a few of these! I only made it as far as the 2nd person that contacted me.
