Rayray85turbo
Does anyone have a list of the part to convert from hot air to intercooler?
Thanks for everyones help.
Thank youSearch, search, and search is the best way to find out.
Thank you .Cheapest and best way to do this is sell it and buy an 86-87 GN. Just saying.
You need to have both cars sitting along side each other. Gut the 85. Install the 87.Does anyone have a list of the part to convert from hot air to intercooler?
Thank you . I' still trying to decide what to do to my 85.Cost me around 4k when I did mine. I bought a complete motor and trans for 3,500 it showed up with a smoked turboBtw thanks and
Dan....
I have an 85 that I’ve owned for 16yrs, so I doubt I’ll ever sell it to me it’s priceless, no matter if I have the HA or the IC setup it’s priceless to me.
The main reasons for my conversion was the upgrade parts availability also maybe it’s just me but I’m always doing something to my car and to be honest it’s seems like everytime you need to do something the turbo has to come out, with the ha motor.
It’s all about you and what you want with your car.
I really should've been a little more clear with what I meant by 'defiling' your HA car. I think(and it's just MY opinion) if you have a really sweet example of a 1985, in very nice original, or even almost original condition car, you may do better to just sell the 85 and find an 86 or 87. I have seen folks ask a lot for nice ones around my area(So. Fla.- so everything is overpriced LOL). Damn close to what IC versions go for. Not sure what they get for them but it does seem the 'overpriced' intercooled years sit A LOT longer on CraigsList, etc. All I'm trying to say is you have a ton of options, and unless you're a guru of Turbo Buicks, swaps can and often do get tricky. Heck, I still am at a loss for what the few extra wires under my hood that just 'exist' but aren't plugged in to anything actually used to go to(guess if I actually did the swap I'd know, maybe...). Either way, do what YOU feel comfortable with doing- whatever makes YOU happy, and you'll be OKThank you . I' still trying to decide what to do to my 85.
Yes sir! Best thing I ever did to the car after intercooling it was move the throttle body. If you have a welder and some basic fab skills it’s not hard to intercool a hot air car.The only way it's worth doing in my opinion, is if you're doing all the fab work yourself because you enjoy it. It can be done properly for not a lot of money if you're building it yourself like I did mine. Biggest thing is that you don't want to have the throttle body mounted on the turbo as it is now, because it turns the turbo and all the charge piping/ intercooler into one huge plenum that sees boost AND vacuum. Transitioning all that volume from vacuum to boost is one major reason all the cheap bolt on kits made back in the day got such a bad reputation for killing throttle response and creating massive amounts of turbo lag. I still used the hot air intake, and welded an elbow to it to mount the TB, and my throttle response is identical to my wife's uncle's '87, although mine is faster once boost buildsHe's still 100% stock.
https://turbobuick.com/threads/intercooled-84.421837/page-3Does anyone have a list of the part to convert from hot air to intercooler?
Mind sharing some pics? Curious on how you mounted the TBThe only way it's worth doing in my opinion, is if you're doing all the fab work yourself because you enjoy it. It can be done properly for not a lot of money if you're building it yourself like I did mine. Biggest thing is that you don't want to have the throttle body mounted on the turbo as it is now, because it turns the turbo and all the charge piping/ intercooler into one huge plenum that sees boost AND vacuum. Transitioning all that volume from vacuum to boost is one major reason all the cheap bolt on kits made back in the day got such a bad reputation for killing throttle response and creating massive amounts of turbo lag. I still used the hot air intake, and welded an elbow to it to mount the TB, and my throttle response is identical to my wife's uncle's '87, although mine is faster once boost buildsHe's still 100% stock.
