Go online with your ECU, go to "view" then "ECU Configuration". See if the radio box for internal datalogging is checked off. If so then you have internal logging.
You can purchase the internal logger from Hartline Performance. They will email you a file with instructions on how to install it. You will need to supply them with the ECU serial number which you can find in the same place you looked to check for the datalogger.
It runs $150.
Does this depend on ECU? I spoke to Hartline and FAST and the way to get it done was sending in the ECU. I heard of someone upgrading on the fly as described, but that wasn't my finding.
The only time you have to send the ecu in, is to get traction control. Because they want to change to a black enclosure. Everything else can be done through flashing and option files.
