I recently purchased Alradco's HID kit -- buying all 4 headlights. FYI, HID's are not two-stage like our outter bulbs normally are. By default the kit comes as outter lights for low-beam, inner lights for high-beam. I want to wire them so that all 4 are on for high-beam.
So, on the low-beam connector, green wire is low-beam, tan wires (2) are high beam and black is ground. I know I need some diode or other between green and tan, to prevent current on the low-beam line leaking onto the high-beam. I tried a 3A diode, but that only lasts a few seconds before it overloads. From my research, I instead need (at least) a 10A diode. Part of me thinks I need a "Schottky Diode." Or, I can hot-wire the headlights like we do various other components using a relay and my 3A diodes. What do you recommend?
DIODE SCHOTTKY 45V 12A DO201AD - SB1245
