What is involed in converting from Digital climate control to manual?
1986 GN with the Digital climate control (having issues see other thread) looking for info on converting to manual climate control.
What needs to be replaced?
What can i keep from the digital system that will work with the manual system?
Details and pictures please.
Thanks for your help
I have a complete digital climate control system that I would sell. It comes with everything except for the resistor that mounts next to the blower motor. Caspers sells it new though.
If I remember correctly when I did mine its pretty straight forward. You need the wiring, control head, manual blower resistor, cable and lever for temp blend door (could be forgetting something). Its best to find a whole donor car or complete box assembly that has been removed intact that way you have all the pieces and you can examine everything before removing parts. Its been a few years since I converted mine but it was easy and I had it done the same day. HTH
