UPDATE: 9.86@137 stock bottom end
forcefed3.8's
Buckeye Bullet
This is in my brothers Cutlass hybrid, it weighs 3520 with driver.
Stock 80,000 mile short block, e85, 83lbs injectors, 60psi base pressure, stock ecm with extender extreme chip, home made double pumper with Reds XP pumps, Reds volt booster, hemco upper plenum, stock throttle body, stock intake with the ends of the runners cleaned up, TE63 p trim turbo@27psi, 210/215 roller, stock rockers, comp 853 lifters, pac 1201 springs, mildly ported stock valve iron heads, stock headers, powerstroke front mount with 2.5" pipes, 85mm truck MAS with a custom 3.5" pipe, PTC 17 blade converter, 6 year old Brian Hoffer trans, stock front suspension with cheap replacement shocks, front sway bar removed, stock rear control arms, stock sway bar, air bag with 23psi in the passenger spring, moser axles, stock driveshaft with brute force u joints, old rusty shocks from the 80s or 90s (maybe even the original 1979?) New bushings in control arms, 275/60 MT pro radials. Car has stock welded motor mounts, factory fuel lines and filter.
1.39 60' off 10psi footbrake
10.007@132 27psi, 10.6afr through the run.
Truly awesome,congrats!
I like when cars run way better than they should with the parts they have.;)
There wont be a next time this year. Maybe next year. I was supposed to convert it to e85 so my brother will start driving it next year, then it turned into run 9s on the stock engine. Kinda got off coarse.
I know, the car is still in the trailer ready to go. I am thinking about it. Next friday is the last race.
