trans cooler lines
dannyv6
I am putting in new trans lines on the GN and i cant rememer where each line went. There are 2 lines comming off the radiator. One Higher up and one lower. Then the two off the trans, one more forward then the other. Which one goes to which one? Or does it matter?
If you do not have an external cooler, other than radiator , it doesnt matter.
Bruce
We4
Bruce
We4
So it doesn't matter how the tranny cooler lines are run. Right now I just put mine back in and have top line from radiator going to bottom port on transmisson
Factory lines: Top port out of the trans to bottom port on radiator, top port on radiator to bottom port on trans.
