My set up is a stock motor with a PT 54, CAS front mount, 50 lb injectors, 9/11 3200 stall, 3" downpipe with 3" exhaust with Ultra Flow bullit muffler, stock gears, stock heads, stock cam, stock intake and throttle body/plenum, with upgraded valve springs from the old Modern Muscle. My problem is the car just doesn't move like it should. It feels decent but it doesn't really go anywhere. I ran a 13.3 with this setup: Joe Lubrant race chip, 114 octane fuel, 21 lbs of boost with virtually no knock but not running rich. I ran 12.78 on about 19 lbs of boost with a 51 turbo and the stock intercooler with my boost going all over the place because of my ATR downpipe (problem was solved before I ran again). I am just tired of trying to figure it out. I am thinking maybe the cam is worn but I don't know how you would tell that. Any suggestions would be very helpful. I have also done the regular stuff like a fuel pump, k&n filter, fp regulator, volt booster, maf pipe, new O2 sensor. Thanks in advance for any advice and help you offer. The car has just turned 100,000 miles also if that helps anything.
Josh
Josh
