Tig welding purge block from scrap copper
Mike T
I needed another purge block for an upcoming project so I'm making one from scrap.
Your going to weld copper?
I've been doing a lot of stainless lately and the purge block is to flood the back side of the weld with argon.... also the copper helps pull the heat out of thin stainless. I will end up tig brazing a couple of tubes to the copper purge block with silicon bronze.
Oh gotcha. I was going to make a copper block with a handle to prevent blowing through my thin floor pans when I welded them in. I didn't bother because I would have needed another Persian to hold it under the car while I was welding from the top. Very cool idea good luck.
I bought this solid piece for back up on long thin stainless edges. It measures 8 x 26 x 1/2 and I'm ashamed to say what it cost...now I know why crack heads will steal your out side AC unit.:eek:
Burning through to the copper will look bad on the underside of those floor pans. Just take your time and trigger it in. A nice and tight joint always helps.
