If you are talking housing size and not the turbine itself, It normally comes ith a .63, but could be swapped for the .85 housing. It was the same price for either when I bought my pt-51 last year.
I'm not certain on he wheel it may be a 76 trim turbine the pt-51 comes with the same 60 trim compressor as the te-44 but has the precision 350 turbine wheel.
HTH!
Also from the turbine housings I've seen they are a little different depending on manufacturer. The turbonetics .82 housing seems a little bigger than the precision .85 and is also bigger than the Garret version. Same goes for the .63 housings. Then again It could just be bad eyesight, maybe someone else will chime in....
