Just a thought, but heat will change resistance. Try setting it with the engine cold and see if that helps. I've seen them fluctuate like your describing, but they have stayed somewhat "stable" enough to not cause a problem. Also during KOEO there is current being drained from the battery, it could be enough to cause a problem when setting the sensor. Make sure the blower motor and radio are off. Check the connections and grounds too.
