Repeat procedure.
WarWagon
Caustic Cacophony
Here are the first few shots of many to come while I get this block prepped to accept all my hardware. This is '85 GN/t-type 3.8 SFI hot air turbo block.
Bent pushrod
Plans are to do all of the same mods that I did to my '83 t-type block. and I'm adding a new rear main seal, timing cover and oil pan gasket. So this is my second block to get my stage 2 setup.
It should run the same as the engine in my car now, if not better than it then. It's got to have less ABUSE on it than I put on my '83 block lol
The cast number is on the bottom drivers side .The reason why i asked is becouse i have a same year block.Im scepticle about it even being a turbo block allthough it does have all the parts of a 84/85 hot air block.
Lol charlie im still a sceptic;)
Yep thanks for the lilttle reminder lol, The casting number in my block is 2552140
Getting my thread back on track, Updates!!!
the Block in cleaned ready for dismantling:
Carnage!
a badly wiped camshaft:
Lifters:
cam buton going to town on timing cover:
Pushrod:
Where'd you come up with the Shiefer aluminum flywheel and what's it for? You gonna sell the cam sensor Adam? Pm me about it.
It looks like it's neutral balanced. You might want to see if it fits either of the engines.
I figured out why we can't post feed back for each other. We did it as a private swap so we have to have some sort of thread reference to leave feedback.:frown:
That aluminum flywheel is bigger than my whole 3.8 flexplate ring gear included. it fits the bolt configuration on my 455 (duh) but the hub in the middle is HUGE it's not touching anything. so I dunno what it's really for, and it don't have a whole lot of part numbers on it.
Oh yeah Charlie I forgot This is the 4th balancer assembly that just slid right off the crank snout with my hands easy. And I'm pretty sure like 100% that GM was the last to put it there. The front cover had never been off before.
It's not for a Buick then. It would be nice if it was but...:frown:
That seems to be normal from what everyone has said. All of the ones I've taken off I had to use a puller to get off. If the balancer has the ring on it I'd be interested in it to when you decide to get rid of it.:biggrin:
