trashmechlv
- Dec 4, 2013
Anybody running boost over 30lb on E85? Looking for actual experience. What kind of timing are you running in 3rd gear? I know all combos are different. Looking for general reference. Thanks
Wow I didnt think I was going to hear timing that high at high boost.24 degrees
Wow! Thats some boost and timing. Im going to be running at track this friday with my new Bison 6465. Im at about 32lb boost with 19 timing. Going to tune from there.I was running 38 psi & 24* deg.'s on my white T which ran 9.3's @ 144. Fuel always tested 88% on every race day. Car ran on a stock ECM with Eric's S/D chip setup.
What kind heads are u running?Wow! Thats some boost and timing. Im going to be running at track this friday with my new Bison 6465. Im at about 32lb boost with 19 timing. Going to tune from there.
Stock unopened engine.What kind heads are u running?
Oh ok, you have good springs i assume right?Stock unopened engine.
Yes I have Comp 980s.Oh ok, you have good springs i assume right?
that's getting it doneI was running 38 psi & 24* deg.'s on my white T which ran 9.3's @ 144. Fuel always tested 88% on every race day. Car ran on a stock ECM with Eric's S/D chip setup.
Good enoughYes I have Comp 980s.
Forgive me for asking what might be considered a dumb question. I don't use E-85 yet so I would like to know this.I was running 38 psi & 24* deg.'s on my white T which ran 9.3's @ 144. Fuel always tested 88% on every race day. Car ran on a stock ECM with Eric's S/D chip setup.
Since E-85 is available at the pump, does this mean you leave this tune and boost exactly the same when you decide to go out for a daily cruise? For example, I drive my car every day in the same trim and what was tuned at the track, aside from my constant tinkering with little things. There's no reason to change it because it was run on pump gas.
Just trying to get a handle on what my peers are doing these days and the whole 38PSI thing.
I believe it, i've ran my car to 41 psi & a small shot of nitrous as well. You can look up a video on YouTube as Gabby Rojas & you will see many videos & there's one of me doing some testing on some back roads lolLocal guy has an MR2 with a Honda K20 swap. He runs 41 lbs of boost on E-85. I know its a lot different engine but he still made 921hp to the wheels.
