Forced to sell due to being laid off.. On Center "153" block. Block has no damage, The ears were cut off at one point in it's younger years, but were welded back on at some point. Later casting front cap has 4 bolts. Bore 3.965, Bushed lifter bores, BMS 3.50 std./std. crank, Carillo 6.5 rods, J/E pistons. Solid Biller roller cam 232/232. .060 Cemetics, 9.125 cr. Comp 7/16 pushrods, White Racing HV front cover and External Oil Pump, Stage II ported heads, done by Ruggles. T&D shaft mounted rockers. BMS hub, JW wheel, Custom sheetmetal oil pan, HR S2 motor mounts, RJC Billet pullys, Only thing motor needs is intake. The motor only has Dyno time on it, but I would be willing to take it back to the builder and have it gone through once a deal has been made. Only had 1 clean run on the mustang dyno. Had issues with the ATR headers. At 6psi it made 425 to the wheels. The motor is still in the car, hopefully will be out in the next week or so... I can email more pics of the motor to serious parties. $7,500
