3.8L V-8 eater
- Jul 22, 2006
Hi, to all
I have my motor on the stand and just put the front cover on. Next I need to put on the oil pump, but noticed that the 2 oil pump gaskets I have are different. One has the opening next to the feed line hole open and one does not
So, which do I use or does it matter???? On a side note I have done the Earl Brown mods to the front cover and this is a stock oil pump. No high volume pump with the extra plate.
I've attached a picture of the gaskets and you can see the one on the bottom is a different color and has the opening closed off where the one on top does not!!! In the picture it looks like the retangular hole next to the feed line hole is open but you are actually looking at black gasket material between the 2 bolts on the top.
Thanks!!
Thanks!!
