Dr. Jeckel
- Jul 29, 2003
The breather line from the valve cover has been replaced with just a filter/breather. I took off the maf pipe yesterday and there was a little stream of oil in the inlet bell. It had not made it to the end of the bell yet and was sitting overnight before i saw it. How bad is this or is it somewhat normal. I shouldn't think you want any oil leaking into your intake air. How much longer before it goes out if this is bad? It is a stock turbo with about 60,000 miles on it (this is what I was told when i bought it). Will it cause any damage, since the car is used just for transportaion right now?
If I have to get another one I would like to get the TA49 and 42.5# injectors. Would this work well together?
Thanks, James.
Thanks, James.
