Some of us run plugged/blocked oil bypass valves in the filter adapter, to positively prevent engine shrapnel from getting spread thru the engine.
The stock oil bypass is set very low, some say it will crack open with as little as 7-8 psi.
Even if using a Biggie filter adapter and super-large Baldwin B9 filter [ http://community.webshots.com/album/36060495QXkyhh ], there is still some risk of collapsing the filter element and blocking oil flow to the entire engine
Here's a possible work-around, although I caution I haven't tried it yet.
1) note that Delco PF24, Baldwin B9, and related "biggie" filters have NO bypass in the filter. The GM design assumes there is a bypass in filter adapter.
2) The Baldwin B253 filter is same physical size as the super large B9, and in addition has a 20 psi built-in bypass! (contrasted to the 7-8 psi stock GM bypass).
3) the B253 also has an anti-drainback valve, and is even heavier guage steel than the B9. B253 is rated to 600psi typical burst. (don't know the rated differential pressure).
4) Minor Problem - the common B9 has 13/16"-16 threads, the B253 has 3/4"-16 threads (1/16" smaller).
5) Solution: re-thread the Biggie adapter from 13/16 down to 3/4".
In summary, the minor modification to use a B253 may be a good tradeoff. With warmed-up oil, I suspect all the oil would be going the the flter and none thru the 20 psi bypass. (although I don't know for certain).
The B253's built-in 20 psi bypass valve seems a reasonable compromise between not allowing shrapnel thru the engine, and avoiding filter collapse on a cold startup, or if too much RPM is accidentally engaged before warmup.
I have installed a B253 as a remote mount tranny filter, so it will be convenient to stock only 1 filter type for both engine & tranny.
