scot w.
GNSperformance.com
- Feb 19, 2005
These new rear frame brace brackets allow you to make your own rear frame brace! You will have to supply your own cross bar and weld it to these braces cause each and every frame cross bar will be different sizes.
http://www.gnsperformance.com/#!bodyframe-g-body/c15ae
These brackets are laser cut and CNC bent then Tig welded
The reason for just making the brackets and not the cross bar was for several reasons:
1) Shipping
2) Each bar will be a different length due to manufacturing
3) Some may want round stock, some may want square stock
Simply remove your bumper and bumper isolator/shock supports, bolt these right to your rear frame ends and measure for your bar then cut your bar to fit and tack weld it in place, remove the brace and finish welding then have it coated to your preference then it will just bolt right back in place and you will have a
completed rear brace at an affordable price!
1) Shipping
