Just got ScanMaster
Originally posted by OKTurbo
Sounds like you've got the right idea on the TPS setting...
The values given above are for engine warmed up idling in Park.
The IAC numbers WILL go up a bit when you put it in drive since the motor is under more load.....they will go up even more if you switch on the air conditioner...
John
My point exactly. I've seen a lot of talk about IAC's in the 30's, but on my car, engine warm and in park, my IAC's are at 0. In gear I will see 25-28 max.
Also, while adjusting your TPS, pull it towards the front of the car. This will make it easier to get .42 at idle and a minimum of 4.6 at WOT.
HTH....Bill
John,
I have not had time to play around. I'll mess around with it tonight after I leave work and I'll post what I get....Appreciate you and the other guys, really been helpful...I'm learning slowly but surely..
Thanks,
Todd
