Is ecm toast?
marcus jul
I was moving my ecm to behind glove box to install q logic kick panels. I screwed up and touched the ecm behind the glove box latch and blew the interior light fuse. I changed fuse,now when I turn on ignition the fan comes on and no start. Scanmaster reads 2.1 then goes blank. Any help would be appreciated.
sounds like it. make sure no other fuses are blown
what does the check engine light do when you key on?
First off thanks for your help, I was wondering if the powerlogger is fried also. I have a new ecm coming and was wondering if I needed a new power logger. Thanks.
when the ECM fries internally it usually kills everything.
Bob
I didn't mean that anything outside of the ECM / chip / Powerlogger would get damaged. Just those.
low impedance drivers will survive this and can be transplanted. If thats what you mean.
Bob
