I need help from the alignment experts.
What are good settings (camber, caster and toe-in) for a G body that is strictly a drag car capable of mid 8s?
And please, please explain why any specs different than the OEM specs would be better for drag racing.
Is it recommended to have the driver in the car for the settings? OEM says car empty. Full fuel tank of course.
Is there an amount of artificial front end lift the car should be put at to simulate a raised front end during acceleration? One inch? Two inches?
For reference only. The 84 factory manual states:
Caster service checking +3.0 +/- 1.0 degrees. Service setting +3.0 +/- .5 degrees.
Camber service checking +.5 +/- .8 degrees. Service setting +.5 +/- .5 degrees.
Toe-in service checking .15 +/- .1 degrees. Servide setting +.15 +/- .05 degrees
(degrees per wheel)
Cross Caster service checking, no more than 1 degree side to side variation. Service setting, no more than .5 degree side to side variation.
Cross Camber service checking and service setting, same as above.
(degrees per wheel)
