- May 26, 2001
These damn cars still kick my ass after 30 years of messing with them, especially when is is an electrical issue?
My recent purchase is a 1986 T-Type that I plan to sell, and it has a driver side power window that will only go up. I figured the motor was bad so I pulled the door panel and removed the electric connector from the window motor and hooked it up to a new motor to check it first.
The new motor will run only in one direction, must be up, but when I check the connector with a test light power is there for both up and down by activating the switch. and figured it may be a bad ground,
I have no clue how to track for a bad ground in a window circuit?
A friend came by later and was telling him about this issue. We were messing with the switches and I tried the driver door switch and with that switch down, the pass window went down as he activated the pass switch?
Appreciate any ideas where to start?
