OK, it's been a while since I was on the list, however, I still lurk. The '28 Essex with the '79 3.8 Turbo is finished. The idle is at about 700 -850 rpm. I can accelerate the engine slowly by hand and all is smooth, however, when I put it in gear it wants to stall , the engine then has a major hiccup and pops back thru the carb upon acceleration. Timing is 15 degrees and the carb has been rebuilt. Mixture screws set at 3.25 turns. Looking for any suggestions and of course opinions. Carb has been professionally rebuilt. Could it be fuel starvation or need a couple of degrees added to the timing?
Dan
Dan
