juan89 Active Member Joined Oct 22, 2008 Mar 31, 2017 #1 How do I remove and repin the main ECU connetor ? Juan
H HighPSI Moderator Staff member Joined May 24, 2001 Mar 31, 2017 #2 They're pull to seat type pins. You will need to push them out, cut the pin, and pull wire back through. Much easier to cut the wire and use a new connector. Either way, you'll need new pins Sent from my SAMSUNG-SM-J320A using Tapatalk
