Car Starts but Dies Right After, CCCI Fuse Blown
nash871233
Thought I had problem solved, but I guess that is not the case. The car starts right up, but dies right after. In this case the CCCI fuse is blown. Replaced fuse and same thing happened. Do I possibly have a bad ground somewhere or could the ignition module have gone bad? I had this problem about a week ago, but at that time the fuel pump was not coming on and I had no spark. I did not have a check engine light either. At that time I found the ECM ignition module fuse blown along with the CCCI fuse. After replacing both fuses car started up and stayed running. A week later, I'm back to the original problem. This time CCCI fuse is the only one blown. Help!
If you take the it apart and see that the goo is melted or maybe one of those wires might be hitting the case grounding out popping fuze.
