Bump box possibilities Eric Marshal ,Bob Bailey??
dank GN
BlackArts Automotive (661)993-8277
I was just thinking to myself with all these bad ass products that Bob Bailey and Eric Marshal have came up with over the years there is really one thing left and that is a bump box to pulse the trans brake . I was using the sd2 to control my boost for awhile and it did a good job at it . Basically you would tell the ecm through the powerlogger to pulse the boost solenoid at a specific rate or duty cycle . And that would control to maximum boost based on what DC you typed in . Now if we switched that to a button to tell the ecm to pulse or Interupt the trans brakes 12vdc signal off for a very short programmed time that would bump you up to the staged light or to the guy pulling you up with the flash light . It makes sense in my head but there are a lot of crazy things that happen in there lol but basically would this be possible Eric or Bob ?
possible, but might not be the optimal solution. I need to research further
Awesome well keep me updated I wouldn't mind testing for you
