Boost leash
TurboDetroit
i wired up my boost leash and it's only making launch boost.
I wired the 12v direct, good ground and the yellow wire (launch wire) to my shifter button. I put an interrupt in between and wired the launch (yellow) to a 2 step switch. The interrupt toggle has a 12v in, ground and load. Load went to the shifter button. Seems to work the way it should via the test light but I'm stuck on launch boost. Ideas or diagram on interrupt wiring? This is simple wiring, lol I wire commercial all day and mess up a damn 3 wire connection
This isn't how he told me to wire my least /bump combo . My trans brake is a 1 wire trans brake . It also sound like you don't have it programmed correctly.
The yellow wire should only have 12 volts at launch . Also he gives his number in the instructions. He will help you set it up . Shoot him a text .or call
