Blown motor or oil pump issue
84sithlord
How can I tell if motor is Blown? Dropped oil pan. No metal. Took oil pump cover off. Some scoring on cover. Would metal be present if motor is Blown? Can the pick up tube be stopped up with sludge? Thank you in advance.
It's a heli cut gear so it should engage the cam gear and turn Alil as you push it down . Also have you tried to prime it with a dril and see if u get pressure ?
Okay have you done a leak down test ? Compression test ? A leak down will tell you a lot of information
