Hi guys,
Me again. Today I made 4 dyno pulls. After each, I was playing with a few things trying to make the engine better. I adjusted timing a little, and fuel too... Now I'm going back to look at the log files, and I'm wondering if anyone can shed some insight on how to use them. I imagine others might like to hear this also.
If you want to look at my log files, see the files in this directory:
Log and GCT File
Now, I have 14 parameters in this log captured, and I think I have most all I need. I'm trying to look things like:
actual AF vs. target AF
O2 correction
injector DC %
Now, my real question is this. How far behind, in terms of frames, is the actual AF vs. the target AF? Obviously it takes some time for the adjustments that the ECU makes to propogate down to the WBO2 sensor. I would like to use this to adjust my VE tables once I get my fuel delivery problems sorted out.
In addition, when I do a dyno pull, would I be better to do it in open loop and just look at the actual AF to adjust the VE tables? For example, when you step on the throttle, you get an extra bump of gas from the MAP AE and TPS delta tables. This causes the O2 to read very rich, and it pulls out fuel. Then you have a period of time for that removed fuel to get back. It seems like the computer is chasing its tail in cases like this...
I guess what I'm asking for is advice from others who have been down this tuning road on what I should actually look at, what I should do for WOT tuning, or for all tuning for that matter... One thing I have tried to do is sitting in the garage, just open the throttle and look at the O2 at various places in the VE tables (the ones you can get to without load on the motor anyway) and try to get the VE entries to provide an actual AF that I like. Is this reasonable? And it only works for a few places in the table anyway...
I would love some feedback on all this rambling! Any and all thoughts appreciated as I start the hard learning curve...
Bryan
Log and GCT File
O2 correction
injector DC %
Bryan
