Where did you guys put your placement of your alky nozzle? Did you use single or dual nozzle set-up? Hot air or hot air intercooled nozzle placement. Pictures if you have them..
i put 2 aquamist nozzels in the rear surface of the intake near the adapter hole then a larger nozzel in the turbo neck. the 2 come in low boost the larger nozzel comes in 15 lbs of boost. john
