- Jan 3, 2012
Finally got around to test fitting my T wheels on the car since adding Aerospace brakes up front a year ago. Turns out they will fit inside a T wheel. About a 1/8in caliper clearance top and bottom but if you have wheel weights stuck on the inside like I do, its tight. Good option for those that want a brake upgrade and still be able to use stock T wheels, although a GN wheel may be different. If someone has covered this already I apologize, but a searched turned up no info.
