Hi,
I'm currently installing a 6466 ball bearing turbo on my car. I'm looking to see if anyone has needed an oil restrictor with this turbo? There is a fitting on the turbo now with a tag that says do not remove, and the paper work says in most cases a restrictor is not needed. I'm just trying to verify this from someone that has installed one of these as my old water cooled ball bearing turbo did need a restrictor.
Thanks for your time
