The motor will make more torque at lower RPM, so most of the time a lower stall converter can work. This answer is if you take a 3.8 and install a 4.1 with all parts from that 3.8L. Camshaft, heads, turbo, ect.
Most end up installing camshafts and over turbo the engine so they end up needing a higher stall converter
