First post here for me. I've got an 88 LeBaron GTS with a 2.5 turbo that's running a 3 bar calibration. To run this setup, I purchases the GM 3-bar cal. My question is on the voltage break up. With an OTC scanner hooked up, key on, engine off, my Map voltage reads 1.3 volts. Is this low? Shouldnt' it be reading 1.667 volts? 5/3 or 1 bar vacuum, 2 bars boost? Thanks for the help!
Douglas
Douglas
