usetaboost
SAY CAR RAMROD!!
- May 4, 2005
First check all your grounds and make sure they are properly attached to the correct location. If you are good there check continuity on the o2 wire. While you are there check to make sure the ecm isn't corroded. It may be a good idea to swap the ecm. Any service codes, maf readings, iac or fuel pressure that are out of whack?
