Go Back   TurboBuick.Com > Tech Arena > Turbo V8 Conversions
Old September 2nd, 2008, 05:25 AM
010 block
Guys I need some info on the small block stuff is the 010 block an oem block? what cars did they come in ?? is the 010 part of the casting #? is it a 350 or 400 truck block ? thanks for any info looking to start stocking up on parts and maybe one day switching over to the other side.
Old September 2nd, 2008, 08:24 AM
jwillettgn's Avatar
010 is the last three numbers of the part number cast in on top of the flange where the bellhousing bolts to the engine. I have one in my 74 L 82 Corvette and it is a 4 bolt main. If I remember correctly they also come in a 2 bolt main in some cases. 350 ci It use to be the block of choice many years ago.
Good luck,
Jim
Wench for Zacks 85GN
750 CSU Blow Through Carb, Weiand intake,TA-61, 85 140 block, center Billet caps, .030 TRW's, race ported big valve iron heads, ATR 309G roller cam, TA performance roller rockers, ATR headers and EX. waste gate, CK 400 turbo with brake,3600 stall converter, 9" rear w/3:25 gears and spool. Hay ya'll watch this.
Old September 2nd, 2008, 09:11 AM
thanks for the info
Old September 2nd, 2008, 09:43 PM
TURBOELKY's Avatar
the four bolt blocks usually came as a truck application, or in a vette. They were said to have a higher content of knickle 69-79. I've had 2 of them, great blocks.
make sure you measure the block. in 68 they made a 327 with same casting number...
1979 turboelky.
Old September 3rd, 2008, 07:45 AM
The Block cast number 3970010 by distributor. And the 010 020 under timing cover issuppose to designate the nickel and tin content as a percenatage.
New Project: 388 cu/in SBC with 94mm Turbo, Air to Air.
XFI w/Traction control <-- for thoes slippery streets...
Old Video of the V6
http://www.youtube.com/watch?v=OXNeK7HIYNY
Old September 3rd, 2008, 08:20 PM
Are we there yet?
I was a teenager in the 80's and my best friend's dad was a mechanic. I know he always said that the 0010 blocks were all 4 bolt main blocks. If there is any truth to it, I don't know, but so far every 0010 block that I have been into has been a 4 bolt main block. It is as good as any other system I guess when you are looking for a junkyard engine to rebuild.
1984 GN. Moonroof, ac, pw, pl, power trunk release,
G80, all stock under the hood minus a K&N.
^ fast ^
V faster V
2004 Impala SS Indy Edition Black and Beautiful
3.4" super charger pulley, FWI, 9"K&N, Reflashed Milzy's PCM, 2.5" cat delete down pipe, colder plugs, colder stat.
Old September 3rd, 2008, 09:47 PM
the 010 2 bolt main block with aftermarket 4 bolt splayed mains and 1/2 fill hard block is as good as it gets as far as gen 1 chevy OEM stuff.
Old Video of the V6
Old September 6th, 2008, 12:04 AM
gofstbuick's Avatar
Administrator
This is a target master block, because I could not find an 010 block that would sonic well and after three sonics at $150 each, this target master block soniced the best. This is a 383, with a cola crank, six inch childs rods, pistons are full float, AFR heads, lots of cam, intake and carb. I plan to put it into my 55 chevy truck. Maybe the best bet for you is to find a block that sonics well and start from there. This engine has seen 6800rpm with no problems (remember, lots of weight to swing in a 383). I do like the idea of 2 bolt main and then installing splayed main caps
87 Buick GN
55 Chevy 3200 Heavy 1/2 Ton
99 Pontiac Bonneville
Joe
Old September 6th, 2008, 04:42 AM
TURBOELKY's Avatar
I think my last block was a target block. It said made in Mexico on the back, and had an option for a dipstick on both sides. I should have installed both
1979 turboelky.
short block 109 block, stock crank and rods .30 over pistons. ATR big cam for sale Rizzer1 Parts for sale 3 May 14th, 2008 08:02 PM
WTB: project engine or heads, bare block, short block, complete, what do you have? Tfreestyle Parts wanted 4 March 28th, 2008 07:57 AM
109 Girdled short block/long block Plus race & stock parts TURBOGTA1 Parts for sale 29 March 2nd, 2008 08:49 PM
Brand New Assembled Short-Block/Long-Block For Sale: NCTURBOS Parts for sale 11 July 17th, 2006 07:35 AM
brass oil sending unit block broken inside block JDSfastGN General Turbo Buick Tech 3 February 16th, 2004 01:00 PM
