Go Back   TurboBuick.Com > Tech Arena > Turbo V8 Conversions
Old February 4th, 2008, 01:49 AM
Turbo Help
Its goin to be a street/strip car high 10s to mid 11s would be ideal. Whats size turbo and A/R would you recommend? Its goin in a notchback mustang.
I know where there is a deal on a PT 70 but the A/R is .63 on the exhaust side. Do i need a bigger A/R its going to be more of a track car then street? Fast spool but what about top-end?
Heres my current set:
Its a 355 SBC
these internals:
Summit Chevy 350 Engine Kits: SUM-SBCKIT1-300 - summitracing.com
Pistons: I have a decent set of forged pistons
Crank:
Eagle Cast Steel Crankshafts: ESP-103503480 - summitracing.com
Rods:
Scat Pro Stock I-Beam Connecting Rods: SCA-25700 - summitracing.com
Heads:
World Products Sportsman II Heads: WRL-012250-1 - summitracing.com
Camshaft:
Lunati Hydraulic Flat Tappet Camshafts: LUN-00012 - summitracing.com
Intake:
Edelbrock Torker II Intake Manifolds: EDL-5001 - summitracing.com
I dont know what to do for a carb... If you see something i should change let me know.
Thanks
Old February 4th, 2008, 02:24 PM
Shadow Master
For the carb, look up CSU carbs, they are hands down the best blowthrough ive ever worked on.
I would venture to say that what you have listed will already put you in the mid-low 11's, so you might want to raise your goals a little.
The 70mm is going to run out of steam around 18psi if your combo is good, and that is too small of a hotside, it would be almost uncontrollable. The perfect turbo would be a 70-76mm, GTS, or even a GTQ, with a .84 or .96 a/r. Dont get me wrong, the 70 will make well into the 600whp arena before you get out of its efficiency range, but im betting its a p-trim exhaust and that is way way to small.
I would use a q-trim if i got it cheap, but that would be on the small side as well. If you want the best of the cheap turbos, the borg warner S400 is the way to go, thats what i use. Less than $600 brand new, and good to around 1000hp if you need it. On your combo it would be mostly a top-end machine, but i think it spools fine as i have traction problems anyway, a little lag is alot easier to control.
Gary
BTW, it is a physically huge turbo, and has a 1.32a/r hotside. There is a 1.01a/r hotside availible for it now, and that would make it perfect for a smallblock. Just loosen the converter a little and its great.
87 Buick T-type WE-4,
6.0L LQ4 iron block LSx,
65# injectors, dual walbro 255s
HP Tuners 2-bar Speed Density EMS
224/224-112 cam,
4L80E, Fuddle 3200stall,
BW s475 turbo, 60mm wastegate,
9" rear 31 spline with spool, 3.07:1 gears,
11" rear disks,
TRZ Manual Rack and Pinion
full 4" exhaust with dynomax race bullets
650hp 585ft-lbs(crank)on 89 octane and no intercooler, 9.5psi-12 degrees timing
11.42@119-7psi
Old February 4th, 2008, 04:13 PM
Thanks for advice! I think s400 is alittle to much for what im tryin to do. Wow
1000hp+StreetCar= Lost of my License LOL
I dont think that Im goin to have enough compression to get me that deep in the 11s on motor it only a 8.8 to 1
im only lookin to make about 550 hp
Old February 9th, 2008, 10:56 PM
single master power t70 .96ar
38mm waste gate
44mm bov
You think this setup will get me the desired HP?
Old February 9th, 2008, 11:22 PM
malibuick231's Avatar
Dont count out the s400. It will be as cheap as a used turbo. Your set up is close to mine but mine is 7.8 to 1. I also have dart pro 1 230cc heads. With the s400 at 10 psi i would bet you my next pay check it will run 10s just playing with it. P.lus you can up grade it for about $300 later if you want to make about 1300hp
The T is running with a best of 10.03 @ 139 getting closer to 9's
Difference between non turbo and turbo Regal fuel pump sending units? d0n_3d General Turbo Buick Tech 3 August 27th, 2007 12:01 PM
Race chips 55s, 3.5 chrome MAF & inlet bell, stock turbo, turbo shield tim87tr Parts for sale 18 August 1st, 2007 04:19 PM
1987 Turbo Buick T, 1983 280zx Turbo, 1997 Taurus SHO *For Sale* CombatComProg Cars for sale 3 August 31st, 2005 09:50 AM
WTB: Aftermarket Alluminum Turbo Bell w/out breather provission hole for Stock turbo. TTA Parts wanted 1 July 22nd, 2005 02:41 PM
Vigilante Stall, Cheetah Turbo, Stock Turbo & Kenne Bell FPR TTA Parts for sale 1 June 30th, 2005 01:21 PM
