60 Foot Times
Went to the track this weekend. I was wondering what you guys do to get good 60 foot times? I was getting 1.78 and 1.76 all day long. I have a 28x11.5x16 et street and I am hooking pretty good. I would like to stay away from a t-brake. I leave of off the e-brake. The car went 11.80@116 mph. I think if I could get my 60's down to 1.6, it would put me in the 11.6 range. Would any suspension mods help? If so what kind? It is stock suspension.
THANKS Joe |
1. Start with around 12 to 14 psi in your slicks.
2. unhook or totally remove your front sway bar 3. put an air bag in the PASSENGER side rear spring($50) w/ around 20 to 25 psi in it. 4. Dont do a john force burn out. Pull through the water box and do your burn out out of the water. Do your burny with the car locked in 2nd gear get the tires spinning and count 1 thousand 1 one thousand two....till you get to 4, then let up and roll out. 5. try launching at 5psi and go up from there. 5 psi w/ slicks should be absolutely no problem at all. 6. watch your fueling, if your to rich on the bottom end your spool will come on too slow after you launch. Also dont floor the car when your trying to build up launch boost. If you dont floor it you shouldnt go into fuel enrichment mode. This will help keep it a little leaner and will help you build boost easier. 7. dont build your launch boost and just hold it there. have your boost climbing when you let it go. basically have your turbo already in excelerate mode when you cut it loose. You dont need big boost to launch hard, you need the turbo excelerating to launch hard. Try this stuff if you like it may help you. I sixty in the 1.4's with 9" slicks leaving off the foot brake at 8 to 10 psi. This is in my 3600# TTA with 3.25 gears HTH: Jason Launches at 15#'s and spraying N.O.S coming soon! Whats funny is that I was close to yanking the drivers side REAR tire last time out (doing 8 psi and no nos).
1989 TTA, twin turbo 275" stage 2 build up, shooting for 9's with "Stock Style" round pistons. 1987 GN, 261" stage 2 build up in memory of Andy Filson, close friend and nephew. Last edited by postal : September 23rd, 2003 at 12:37 AM. |
I only had air in the passenger side air bag. I had probs and ran out of time so never had a hose hooked up to the drivers side to try air in that one. I dont think I'm going to mess with it either. My neph got a pick of me taking off from the drivers side. Sitting still my car has about 1" between rear fender well and top of the slick. The pic of the launch shows about a 4" gap on the drivers rear wheel so I'm twisting bad and lifting up on the whole drivers side of the car.
..........OH **** I just thought of some thing! I dont have a rear sway bar in the car right now! That had sliped my mind completely. I had my car apart for 18 months and it was a fiasco trying to get it running to take it to bowling green. That probably has a huge effect on air bag set up and why I'm twisting so bad...................I got to many irons in too many fires to keep up on every thing. I need a holiday! Jason
1989 TTA, twin turbo 275" stage 2 build up, shooting for 9's with "Stock Style" round pistons. 1987 GN, 261" stage 2 build up in memory of Andy Filson, close friend and nephew. |
Edited my first post............PASSENGER side air bag, not drivers side.
Thats what happens when you do a copy paste. you make the same mistake twice. Jason
If you are still twisting that bad after installing the rear bar, you might want to consider weld in sub fram connectors. Has worked great wonders on our othder thirdgens. I have not installed them on my TTA, but my brother has a High 12 sec 355 4BBL 350 and he went from 13.3 to 12.9 by just installin the sub frame connectors. 60' went frm 1.9's to 1.8's.. an gained .3 to .4 at then end of the track from being able to launch harder once he ajusted to havin them. Same technique as he used without them netted a 13.1 as opposed to the 13.3... he reved another 500 RPM (leaving at 3000 now instead of 2500) and got the 12.9. He runs a 2800-3000RPM stall on a N/A engine.. not a bad $300 investment
06 Torch Red Mustang GT 5-Speed, Hurst Shifter, C&L CAI, JBA Long Tube Headers and High Flow Catted H-Pipe, Borlas and Custom Tune by Evolution Performance. Used to own 89 TTA #1053 Other Toys and projects as well |
Mark Metdker - 1989 TTA #797 GT 3255 Turbo - 38# injectors 7.58 @ 92 mph 1.65 60' http://community.webshots.com/album/56863057VldOYC Fire Pics http://community.webshots.com/album/104144205xDgckj Band pics http://community.webshots.com/album/176544894AuXSmi |
I will be bringing both the turbo car and the big block car to Noble. My bib block car is only running 13.40's, so I don't know if I'll be running it, but it will be there for moral support! I could not, in good concscience, extinguish a burning Mustang.....sorry! ![]()
Postals car has them. I was there when they where put on.
1987GN 90,000mi TE-60,ATR 3" downpipe,walbro 340 hotwired42.5#injectors,SMC dual nozzle alkykit, bowlinggreen recaps,openrearend, 3,690lbs, pumpgas 24lbs of boost 12.68@109 |
Postal thanks for the help. I put about 25-30 psi in my air bag,
and installed a line lock so my brakes will not get hot during the burn out. I did one pass with out any air in air the bag, went 1.75 60 and then put about 30 psi in air bag and went 1.61 60. Thanks |
WOOT! good job
Did you get a burn out procedure down and all that stuff? Did she feel like she grabbed good and hard? Jason
What airbag do you all use for the TTA's???
Joe Reif Jr. Paola, Kansas 2008 Can-Am Renegade 800 CVT beast 2007 Harley Davidson Road King FLHPI SE 103" 2005 Chevy Silverado 3500...Bombed Oil Burner 1987 Turbo-T...light blue exterior/dark blue interior 84k miles Chip programming by: Eric Marshall @ www.turbotweak.com Meth injection by: www.alkycontrol.com My email:pdq6cyl@midwest-connections.com |
I got mine from ATR but I think you can get them cheaper through summit.
HTH: Jason
