Old May 8th, 2002, 11:28 PM
Bobtempest's Avatar
Moderator
Engine will not turn over
The starter will not spin the engine. Starter is new and good. Checked the fusable links okay, but not getting power to solenoid.
Vat system checked out okay on the switch. Neutral safety switch okay. What else could it be? I am trying to help a friend but I am stumped. It has other problems but we have got to get the starter to spin over first. No fuel pressure with the key on either. HELP
Bob Hinson
9.57 @ 3720lbs on the foot brake - TSE Winner 2004 and 2007 and runner up 2005 and 2006
Nothing in the world can take the place of persistence
This is America and English is the language, legally or not. English, the single greatest empowering tool that immigrants must have to succeed.
http://www.us-english.org/inc/
Old May 9th, 2002, 12:41 AM
Did you remove the driver's side kick panel and examine the Vats relay? It is behind the driver's kick panel. You may have to remove a piece of black sealant that covers the hole where the relay is. On the relay there are yellow and purple heavy gauge wires. The purple wire goes to the starter. Verify that you have 12v on that wire when cranking. If not, jumper the heavy yellow to heavy purple. This will bypass the Vats untill you figure out the problem.
Civilization has brought Evolution to a screeching halt.
Old May 9th, 2002, 09:31 AM
GTEATER
Posts: n/a
Not trying to be smart or over simplify, but are you sure the solenoid wire is to the correct post? I've made that mistake before and not got it to the engine side terminal.
Old May 10th, 2002, 04:43 PM
1badTTA's Avatar
Resident Smart A$$
LMFAO
Glad I am not the only one that made that stupid mistake, even took the starter out and brought it to the auto parts store just to notice he hooked up the other terminal. Felt like a real dumba$$. Nice to know it happens to the best of us!!!
Check the ground to the fuel pump and the hotwire relay (if hotwired). If the relay isn't mounted with the mounting tab being grounded good, it will not activate. Trust me on this one, a sheetmetal screw won't cut it forever, it can't hold enough torque to keep a good ground, you need a screw and nut to keep it tight.
'89 TTA #332 12.973@111.45 (on BFG Radial TA's) stock injectors, turbo, intercooler, and downpipe. Hotwired WB340, RJC power plate, ProPain, usual free/cheap mods.
Old May 17th, 2002, 09:02 PM
Stockpiling buicks
the same thing has happened to me maybe 6 times in the 4years that I've had the car. Its not the starter, vats, solenoid etc. it was a real mystery. It happens like very 6-or 8 months. you turn the key and -NOTHING, like if you try to start the car with the shifter in drive. Its in the shop now being looked over.
Dave
87T--White. Moonroof
87GN--TTop. Loaded. New everything
87GN--Moonroof. Mostly stock
TTA656--TTop. Leather **SOLD**
90 Pickup-Blue.
More to come...
Old May 17th, 2002, 09:37 PM
It wasn't by chance hot outside each time this happened was it? Because mine would do the exact same thing. If I let it cool off for about 15-30 minutes it would start. That is caused by GM using too small of a wire going to the solenoid. When exposed to extreme heat the solenoid gets too warm and binds. When this happens it takes more current to move the plunger. I had this happen numerous times (during the summer) and finally fixed it for good by adding a 10g wire right along side the factory wire. I was able to add the new wire inside the factory wire loom so it is undetectable. This only happens on TTA's because the passenger header runs way too close to the starter(and solenoid). If this is your problem don't bother throwing money on labor or new parts at it, because it won't help. Adding the wire WILL fix it 100%.
Old May 18th, 2002, 08:03 AM
Stockpiling buicks
winter, spring, summer doesn't matter.
I will use that tip-what is there to lose.
Dave
90 Pickup-Blue.
More to come...
Old May 22nd, 2002, 01:23 PM
Hi,
I tried the 10guage wire trick and thought mine was fixed till it wouldn't start one day at walmart.
I added a ford solenoid, using the 10 guage wire I added to the existing purple wire and I ran it to the "s" terminal on the ford solenoid.
I ran a 10g hot wire from the positive battery cable where it attaches to the starter to the ford solenoid and then another 10g wire from the ford solenoid to the "s" terminal on the starters solenoid.
It has started every time now since last June or so.
here is a link to where I mounted it
www.geocities.com/jwicmandy
Later,
James
1989 Turbo Trans Am
T-Tops/Leather
AFR, Powerplate, 36# Inj, SS Maf pipe, My own Chip, Translator, 3.5" LT1 maf, STB, Big neck GN intercooler, Magnaflow cat
