Old July 20th, 2008, 11:57 AM
TTA - Need help with routing of the positive battery cable for the alternator
Pre the title. Can't seem to find goo pictures of where this wire is routed.
In the first picture you see which wire I'm on about, second picture shows the P-clips that holds the positive and negative "thick" wires do the thinner positive run through on of these as well?
Where does the thin wire go down behined the engine oil-cooler setup or above and then down? I know it runs in the plastic channel at the bottom of the held in place by the studs for the IC brackets.
Where does the thin wire route from the bottom on the driver side up to the bolt on the alternator? Just straight up behind/between the tensioner and alternator or somewhere else?
Any help or photos mych appreciated so I can get this together and start my engine for the first time after the rebuild.
Old July 22nd, 2008, 04:49 PM
Anyone that can help and take a look at their stock TTA for me?
Old July 22nd, 2008, 06:51 PM
Smile
Jan I can try but it will this weekend. It is still totally stock nothing changed. My car is in storage not at the house now but can this weekend.
Harold
Turbo TA
Like new 86-87 battery positive cable and some hoses d0n_3d Parts for sale 3 October 3rd, 2006 08:45 PM
Routing of new positive battery cable. artrenee10 General Turbo Buick Tech 4 February 14th, 2005 08:21 PM
positive battery cable ulose2av6 General Turbo Buick Tech 1 August 4th, 2003 09:00 PM
cheapest positive battery cable replacement? TType84 General Turbo Buick Tech 4 November 26th, 2002 09:39 PM
Need help w/ positive batt cable routing/bracket under crank pulley QuickWE4 General Turbo Buick Tech 2 September 2nd, 2002 06:38 PM
