Old July 10th, 2008, 01:08 PM
Speedo Gear Change
Hey guys I need to install the correct nylon spedo gear in my car to offset my new ring and pinion size to get the correct spedo reading. My question is where is this nylon gear located at on the trans? Is it by the spedo cable itself? inside the tailshaft housing? Do I have to r&r the driveshaft? Im kind puzzled where this simple gear is located at?
Old July 11th, 2008, 02:09 PM
Razor's Avatar
Forum tech Advisor
There are two gears. One on the VSS and one on the tranny's main shaft.
The main shaft in the tranny.. to change this one. requires complete dis-assembly of the tranny.. as the Main Shaft is the very first part installed when building the tranny.
There are MPH calibrators in the afternmarket. Your speedo on the TTA is electronic. So it would be a case of installing a recalibrator onto the VSS.
HTH
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old July 14th, 2008, 12:32 PM
Thanks for the reply. Where would one locate this calabration tool for the VSS? Is it like a plug and play harness/sensor or something programmed into the pcm? I thought the only way to correct it was to change the spedo drive gear?
Old July 18th, 2008, 07:59 AM
Any Ideas on who sells this type of recalabrator?
Old July 25th, 2008, 10:37 AM
Anyone?
Speedo gear change Boostin TA Transmission Talk 1 June 23rd, 2008 12:44 PM
TH400 speedo gear change ? KWIKR 1 Transmission Talk 4 November 13th, 2006 02:13 PM
How hard is it to change speedo gears? Buffalo Dude Transmission Talk 6 June 8th, 2006 01:41 AM
speedo change over acmech1 General Turbo Buick Tech 2 May 20th, 2005 08:43 AM
should i change speedo gear? GNX423 Transmission Talk 1 May 28th, 2003 01:28 PM
