Finally... Sweeeeet :d
89 TTA Stock appearing 10.550 at 132.22 1.539 60ft 3850 race weight w/driver Always on 93 octane www.alkycontrol.com 727-570-9999 |
It's only taken 34 months to get to this point...a lot of time and a boat load of $'s.
Julio, do those plug wires look familiar?
1989 Turbo Trans Am #178, "291" 4.1 with ported irons and intake, rollerized valve train, 210/215 roller cam, PTS 9/11 3200 T/C, CPT66 BB, stock IC with Duttwieller neck in the works. Previous combo: 11.79 @ 114.7 w/1.61 60' all time best with TA49. ATR bleed valve to control boost, Ext Chip - 23/19 timing, Translator Plus, LT1 MAF Sensor, 62mm T/B, ported plenum, 1" plenum spacer, 60# MotoTron injectors, Adj F/P reg, Walbro 340 F/P, Action Fab 3” D/P, freeflowing exhaust with testpipe, 110# valve springs, PTS 9/11 Lock-up 2800 T/C, BFG Drag Radials on stock rims, Spohn Adjustable Torque Arm, Global West Subframe Connectors, Spohn Adj Panhard Rod, Spohn Lower Control Arms |
Very Nice!!!!
TAI winner 06, runner up 07, winner 08 SOLD!! 86 GN(GNX clone) 67 tubo,ALKYCONTROL,M/T D/R, 50's, RJC P/P,9/11 3400 con.,T/Tchip,NEW 11.66@116mph NEW!! 86 GN (the new GNX) te45a,Precission F/M, fast bank to bank,billited main cap motor, billited roller cam, 55lb inj.,ALKYCONTROL, New best 11.12@122mph!!!! 89 TTA 1092, 67 turbo,ALKYCONTROL,M/T D/R, 65's, RJC P/P,9/11 3500 con.,T/T chip,NEW BEST!! 10.85@124mph WOW!!!! 86 GN stock 175,000,basic's,13.20@100mph
Looks very nice! What kinda times you shooting for?
89 TTA with built 109 .040 over J&E pistons,K1 rods,billet steel caps,steel crank,224/224 flat tappet comp cam,HV front cover,port matched intake,fully ported TTA heads,PT70 turbo,KM sheet metal intake,50# injectors,billet fuel rails,TT chip,NX nitrous wet shot system,3'' THDP,SM2,Razors alky injection,vigilante 3200 stall,fully built tranny,drag bags,convo pro wheels,15x9x30 Hoosier slicks in back with 15x3.5x28 skinnies up front. 6pt cage for now. Coming soon to a strip near YOU! ![]()
When I was first considering this 4.1 combo, I was thinking I want to run very conservative boost levels and not have really lean on the motor hard to run 11.0's or 10.90's, so to play it safe that is what I am conservatively looking for. In the past I have been "balls to the wall" running the the stock combo has hard as I could to achieve the best times. I guess we will see how it runs, once it is broken in correctly and I figure out the "tune", and the lure of that best ever timeslip overcomes my conservative nature.
1989 Turbo Trans Am #178, "291" 4.1 with ported irons and intake, rollerized valve train, 210/215 roller cam, PTS 9/11 3200 T/C, CPT66 BB, stock IC with Duttwieller neck in the works. Previous combo: 11.79 @ 114.7 w/1.61 60' all time best with TA49. ATR bleed valve to control boost, Ext Chip - 23/19 timing, Translator Plus, LT1 MAF Sensor, 62mm T/B, ported plenum, 1" plenum spacer, 60# MotoTron injectors, Adj F/P reg, Walbro 340 F/P, Action Fab 3” D/P, freeflowing exhaust with testpipe, 110# valve springs, PTS 9/11 Lock-up 2800 T/C, BFG Drag Radials on stock rims, Spohn Adjustable Torque Arm, Global West Subframe Connectors, Spohn Adj Panhard Rod, Spohn Lower Control Arms Last edited by AKTURBOTA : June 27th, 2008 at 11:25 AM. |
| """""""""""""""misc Motor Parts""""""""""""""" | TurboIndian | Parts for sale | 20 | January 25th, 2008 04:35 AM |
| Removed 3" Flowmaster 40, installed 3" Dynomax Ultra flow welded, and WOW!!! | BetMinesFaster | General Turbo Buick Tech | 3 | November 19th, 2007 03:57 PM |
| T/A performance valve covers "installed" | PaCemkr86 | General Turbo Buick Tech | 65 | August 24th, 2007 05:27 PM |
| 4.1 "291" Block and "515" Casting Cyl Heads | AKTURBOTA | Turbo Trans Am Tech | 4 | May 6th, 2007 09:29 AM |
| Installed valve spring height - 1.70" at 80-90 lbs, or 1.727" at 100-110 lbs ??? | Rob_85Ttype | General Turbo Buick Tech | 5 | August 9th, 2002 01:11 PM |
