Old May 23rd, 2008, 09:47 PM
ttafan's Avatar
Ever closer to the 9's
Took the TTA out to the track tonight to try out the new 4" exhaust and 3" up pipe I installed last week. She's breathing now. I love peoples reaction to this car when I pull in to the pits. They're shocked it's a little V6. Stock wheels, stock intercooler, factory block, factory iron heads, factory intake, cold A/C, and looks like I drove it off the lot back in '89. Here's some numbers from one of my runs. A personal best. I am very pleased with the way she's running. Getting faster every time as my compfort level increases. Not quite used to launching a car so hard that it pulls my foot off the gas pedal from the G forces!
R/T ... .667
60' ... 1.524
330' ... 4.277
1/8 ... 6.595
MPH ... 105.79
1000' ... 8.611
1/4 ... 10.333
MPH ... 130.05
Old May 23rd, 2008, 09:52 PM
That is flying! Congratulations!
So what is your go fast recipe?
89 TTA, 23,000 miles, AEM boost controller, sfc, 8" K&N, PI 3000 stall, Caspers heated 02, 3" SS downpipe & interm pipe, MT ET street drag radials, Precision 50# injectors, Turbo Tweak chip, 12.42 @ 107 with very humid head wind.
Coming soon: Precision DBB Billet 6262rs, LS1 MAF & translator, 109 block w/ 4.1L stroker, RJC girdle, ported stock heads, bigger valves, custom ground Erson flat tappet cam, comp 980 springs, RJC power plate, Dutt neck to stock intercooler, custom 3.5" MAF pipe, etc
Old May 23rd, 2008, 10:25 PM
ttafan's Avatar
Well, I tell you. It's a combination of patients, money, time, and learning to tune. I use the FAST XFI. 70mm turbo. ATI TH400 trans w/ non-lock up converter and trans brake. Champion ported heads. Alky control kit. Comp Cams roller. ATR down pipe. Moser rear. Spohn torqe arm. Mufflex 4" exhaust. M/T ET street tires. And a bunch of other stuff I can't even remember. The only guage I have in the car is a boost guage. I also use a shift light. All my other info comes from my laptop data logger..... I have to thank Anderson Performance for building alot of the car. It's been a long process, but well worth the wait. I will snap some good pics of the car this weekend when the sun is shinning and I wash all the shoe polish off.
Old May 23rd, 2008, 10:37 PM
Scott89TTA's Avatar
nice job Trent...sooooooooo close, she's definitely flyin' looks like 9's are just around the corner
Scott
Scott89TTA
1989 TTA #1376
48K...GT6776e, RJC MBC, Alky Control, Scanmaster 2, LT1 MAF w/Translator, 3" MAF pipe w/K&N X-Steam, 3" Up-Pipe, 3" S/S Action Fab DP, 3" Test Pipe w/QTP electric cutout, 100# valve springs, RJC PP, 60# Motrons, Walbro 340M w/Racetronix hotwire, 160 deg t-stat, TurboTweak 93/Alky chip, Anderson Performance Trans w/StageRite Brake, Billet TCS 9/11 3400-3600 converter, PTS Aluminum Pan, M/T DR's 255/50-16.
P&P heads and cam next Winter if all goes well
Old May 24th, 2008, 11:15 AM
GNBRETT's Avatar
Helms Deep in Debt
Thats impressive.
Brett
The world is full of whiners......
1987 Black Turbo T, Stage II, F.A.S.T XFI w/ ITC, Precision 76mm Turbo, Champion GN1-R Heads, Champion Race Ported Intake, PTC Converter, MSBC-1 Boost Controller, RJC Polished FMIC, RJC Pulleys, RJC MAF Pipe, Turbonetics Godzilla BOV, Rzrs Dual Alky Kit, Lonnie Diers Billet 2004r w/Elect TB, HR 224/224, ATR's, Tial WG, Oil cooler, Deep Oil Pan, 83# Lb. Inj, Aeromotive Fuel, Callico Coated Bearings, March Perf. Billet Alt, Girdle, Savitske Stainless Upper/Lower Control Arms & Ball Joints, Metco Upper/Lower Rears, ATR Sway Bar, Aerospace Front & Rear Brakes, SBC Springs, Hydratech, 3.5 in Custom Exh, 6 Point Chromoly Bar, Custom Bogart Welded R/T's w/ MT DR's, Bilstens, Ice Cold A/C, Eclipse. Tuned by Otto J.
Old May 24th, 2008, 02:58 PM
Jicaju's Avatar
Jicaju
Car is pulling hard. Congrats on your times. Sounds like it time to get mine back out.
Old May 24th, 2008, 10:11 PM
Razor's Avatar
Forum tech Advisor
Congrats Trent.. she's moving on out.. time to update your info.. this is the fastest 109 block TTA I know off.
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old May 25th, 2008, 08:03 AM
jasjamz's Avatar
"Hot Air"
Thats Fast! How much Timing and Boost are you running?
85 T-Top GN 235 HP!!
Old May 25th, 2008, 08:41 AM
Good job!!! Thats hauling the mail.
Razor, was the TTA on the cover of ATRs old catalogs a stage II car?
Chris Campbell
Engine Machined @ Jackson Cylinder Head by Geoff Burroughs
Engine Built @ Alexanders Automotive by Randy Alexander GN>Girdled 109 , TRWs std bore , 218/212 roller , T&D 1.65s , 70mm TB/plenum , ported irons, intake and exhaust (Randy A) , PTE FMIC , te45a , stuff to make it all work.....10.84/125-stock MAF
TurboTweak chips...thanks Eric!
06/01/08 update...CruzMissile in the works....
TTA..."wifes" car
Old May 25th, 2008, 10:33 AM
1BADDAM's Avatar
Venomous Snake Handler
ATR's was a SGII and so was Bill Sake's 9 sec. TTA. both were in the catalog.
Frank
TTA#1416
11.78 @ 117 1.86 60'
Old May 25th, 2008, 06:57 PM
ttafan's Avatar
Thanks for the replies everyone. I really love my TTA. I have wanted to own one since they came out in 1989. I was only in high school at the time and I was learning about the power of turbo boost. I was lucky enough to be in the family business and work at a GMC dealership when the Syclone/Typhoon's came out. I got ahold of a '92 Typhoon and the turbo addiction began..... A buddy of mine worked on GN's and had a fast 11 sec. stock turbo T-type. One night, at his shop, we were working on my Typhoon and someone from North Carolina drove his TTA up to Maryland to have some work done on it. I sat inside the TTA for the first time and knew someday, I would have one. Now, over sixteen years later, it's a reallity and I could not be happier! Here is the updated Info. I will try to clean her up tommorow and get some good detailed pics posted from underneath the car, up on the lift.
Details of the run:
60' ... 1.524
330' ... 4.277
1/8 ... 6.595
MPH ... 105.79
1000' ... 8.611
1/4 ... 10.333
MPH ... 130.05
Screen Name or Car Number Here: TTAFAN
EMPTY WEIGHT: 3650lbs.
BLOCK: Stock, bored 30 over
HEADS: Stock, Champion Ported
CAM: Comp Cams 114-114
TRANSMISSION: ATI TH400
TORQUE CONVERTER: ATI 3800 non lockup
DIFFERENTIAL: Moser 3.73
INTERCOOLER: Stock w/Duttweiler neck
THROTTLE BODY: 70mm
RJC POWER PLATE: No
INJECTORS: 95 lbs.
THERMOSTAT: 160
TURBOCHARGER: Prescision 70mm
VALVE SPRINGS: 100 lb.
MAF: None
DOWN PIPE: ATR 3"
EXHAUST: Mufflex custom 4"
FUEL PUMP: Walbro double pumper
FUEL PRESSURE REGULATOR: billet adjustable
FUEL PRESSURE: 50 lbs.
ALCHOHOL INJECTION: Razor's Alky Control
PROPAIN INJECTION: No
NITROUS: No
AIR FILTER AND AIR INTAKE: K&N 9" cone w/ custom 4" MAF pipe
TIRE DESIGN, SIZE & AIR PRESSURE: M/T ET Streets 16/11.5/26.1
AIR BAG(s): No
SUSPENSION: Bilstein Gas
SCAN TOOL: Fast XFI Laptop
FUEL: VP C16
CHIP: FAST XFI
CHIP TIMING: 22 deg.
KNOCK RETARD: None
OXYGEN SENSOR VOLTAGE: 10.2
EXHAUST GAS TEMPERATURE:
TRACK ELEVATION: sea level
TEMPERATURE: 60 deg.
PEAK BOOST: 26 lbs.
BOOST AT LAUNCH: 10 lbs.
MILES ON THE CAR/ENGINE: 9,000
Old May 26th, 2008, 08:41 PM
ttafan's Avatar
Well,..... as promised, here are some pics. Please enjoy!
Old May 26th, 2008, 08:43 PM
ttafan's Avatar
A few more.
Old May 26th, 2008, 08:45 PM
ttafan's Avatar
Some more.
Old May 27th, 2008, 11:58 AM
Those pictures are going to cost me a lot of money over the next few years. Now I want to do more modifications to my car. Your car really looks great!
Do you drive the car much on the street? With 3.73 gears and a 3 spd transmission I wouldn't imagine it would be much of a highway cruizer anymore.
Congratulation on your times. This gives me something to shoot for!
Old May 27th, 2008, 01:28 PM
vacuum 6's Avatar
Half-Roofs do Rock!
VERY NICE!!!!!!!!!!!!!!!!!!!!
Walter Boss
-My 1987 Turbo T-
New motor (full street trim):
12.022 @ 115.35 19# of boost & 24°/22° E85 & 89 mix with alky (109 with 212/212 roller, GN1s, Champion intake, Turbo Tweak, Alkycontrol, V2, MTDR, 009s, 2800 12" & TE60)
Stock motor:
12.32 @111.XX unleaded 100 and DRs, 12.25@ 110.XX 25# of boost & 27°/24° (DIY alky, 93 octane, TT chip, and DRs)
Old May 27th, 2008, 08:31 PM
Very nice! I have one question, Did you put the roll bar in not to get booted out of the track, or could the car not handle it with just connectors in it? Thanks and congrats again, lets us know when your in the 9's!!!
Old May 27th, 2008, 09:41 PM
ttafan's Avatar
Thanks everyone. I put the cage in to prevent chassis flex and prevent getting booted. I ran an 11.30 or something last year and got kicked out and I knew I was not finnished with the mods yet. Even though I only make a handfull of passes a year, I decided to go with a cage. It is a full cromoly cage with swingouts and is 8.50 certified. I think it looks good in the car compared to some I've seen. It was not cheap that's for sure. I'm probably done at the track till fall as it's starting to get pretty hot and humid up here. Not Ideal to lay down a good number in a turbo car.
  #19 (permalink)
Old May 27th, 2008, 09:46 PM
Razor's Avatar
Forum tech Advisor
Nah.. go to the track and keep getting frequent flyer miles... and have fun with it. I would set the boost on my TTA to 20 PSI and run high 10's at 124.. and enjoy driving to the track and back.
Come fall.. turn it up.. lay the number
Always on 93 octane
www.alkycontrol.com
727-570-9999
  #20 (permalink)
Old May 28th, 2008, 07:00 AM
EightSecV6's Avatar
MDBL
Congratulations Trent, you surely deserve it! Still on a conservative tune as well! Glad you are getting some seat time.
Bill Anderson
Anderson Performance Automotive
8209D Rosebank Ave.
Baltimor
