Old May 11th, 2008, 06:45 PM
2004-R diff than GN ?
For awhile I thought the 200's were different when we looked @ Frank the Beermans' car because of the electronic speedo vs the mechanical in the GN. But now looking again, I think that we have a different insert into the speedo area which takes our electronic module.
Sound right ?
Lynn D. Brown
finally back in SoCal
'87 GN, '89 TTA,
'93 Typhoon, '06 GTO
Old May 11th, 2008, 06:50 PM
Buick "RICER"
Trader Rating: (12)
ya its a speed sensor ... pricey bugger to .. unavailable for years
Dan
Old May 11th, 2008, 10:05 PM
Wink
Hi,
Good luck!
***83 Buick Regal TType***
'87 drivetrain and all associated stuff.
Fresh rebuild with Stock block,ARP studs installed with stock caps,align bored to ensure proper fit.Sealed Power forged pistons,stock rods,resized for ARP bolts,stock heads with low cost stainless valves,206/206 Comp flat tappet cam, TA49 turbo,009 injectors,hotwired Walbro 340, Hooker cat back exhaust,K&N filter in stock airbox,Spearco water injection, pretty stock otherwise.
***89 Pontiac Turbo TA***
Walbro 340, Flowmaster muffler, otherwise stock.
***96 Buick Riviera***
3.6" blower pulley,otherwise stock.Runs 15s on a hot day at 4000 plus pounds weight, with the A/C on.
***84 Jeep Cherokee 2door 4x4***
87 Turbo Regal motor,thm700R4,rusty wild child,definitely a restoration awaiting progress.
Old May 12th, 2008, 06:47 AM
Razor's Avatar
Forum tech Advisor
The case on all 2004r's is the same. They were all cast the same. As far as Buick and TTA tranny's.
Now I dont know if the plastic gear on the shaft is the same on the TTA and GN.. that is a good question as gear ratios are different between both cars.
Valve body is suppossed to be calibrated differently to help with the "clunk" that the GN's do when going into gear. That is why the GN is a BRF and the TTA is a TAF. Probably couldnt tell the difference.
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old May 13th, 2008, 12:26 AM
Interesting, Razor. More for the knowledge banks.
Lynn D. Brown
'87 GN, '89 TTA,
How to tell diff between a 2 & 3 way cat. channer Smog tech and emissions tech 8 November 17th, 2005 02:00 PM
Diff between ser l and ll only"T"intown 3800 Supercharged Tech 16 November 10th, 2005 10:14 AM
open diff-posi diff 383 Buick Regal General Turbo Buick Tech 2 October 17th, 2003 11:25 AM
diff. oil ? denn454 Transmission Talk 11 June 11th, 2003 02:44 PM
84/85s vs 86/87s what's the diff? Jebadias General Turbo Buick Tech 6 July 24th, 2002 03:02 PM
