Old May 3rd, 2007, 05:12 PM
AKTURBOTA's Avatar
4.1 "291" Block and "515" Casting Cyl Heads
I have a "291" 4.1 liter short block and "515" casting cyl heads. What have other TTA owners used as head bolts to correctly fasten the cylinder heads to the short block? It seems that the crux of the dilema is fastening 3.0 liter cyl heads to the 4.1 block requires a special or custom head bolt.
1989 Turbo Trans Am #178, "291" 4.1 with ported irons and intake, rollerized valve train, 210/215 roller cam, PTS 9/11 3200 T/C, CPT66 BB, stock IC with Duttwieller neck in the works.
Previous combo: 11.79 @ 114.7 w/1.61 60' all time best with TA49. ATR bleed valve to control boost, Ext Chip - 23/19 timing, Translator Plus, LT1 MAF Sensor, 62mm T/B, ported plenum, 1" plenum spacer, 60# MotoTron injectors, Adj F/P reg, Walbro 340 F/P, Action Fab 3” D/P, freeflowing exhaust with testpipe, 110# valve springs, PTS 9/11 Lock-up 2800 T/C, BFG Drag Radials on stock rims, Spohn Adjustable Torque Arm, Global West Subframe Connectors, Spohn Adj Panhard Rod, Spohn Lower Control Arms
Old May 4th, 2007, 12:16 PM
Last I remembered u need two sets of GN ARPies to make one TTA set.
As far as headbolts go at least:-)
No one makes a TTA specific headbolt set.
Maybe try dealer for stock bolt set?
later
Jeremy
Old May 4th, 2007, 12:28 PM
AKTURBOTA's Avatar
The solution at hand to mate the 515 heads to the 291 block was to place a special order from ARP:
4 bolts 4.0" long
4 bolts 2.875" long
8 bolts 2.0" long
Cost $59.75 plus shipping.
It appears that the 291 block has the threads recessed approximately 3/4" into the block. When we started this engine project...never anticipated the issues that have cropped up...live and learn.
Mark
Old May 5th, 2007, 08:09 AM
Razor's Avatar
Forum tech Advisor
The bolts dont go through like on the 109 block.
Thanks for the heads up on the lengths.
Julio
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
http://stores.ebay.com/ALKYCONTROL_W...eNameZl2QQtZkm
Old May 6th, 2007, 09:29 AM
AKTURBOTA's Avatar
Figured that I might as well pass on what I learned.
Mark
Board members "Quick6'n'-K.C." and "8UWITH6" feature cars for the month of October. 86brick Turbo Video's and Picture Library 24 December 5th, 2006 09:28 PM
"85" full block and 8445 heads! scot w. Parts for sale 2 April 6th, 2005 07:21 PM
"o" ringed heads, why not the block Sam Colalillo General Turbo Buick Tech 3 January 19th, 2005 08:19 PM
Valve spring ID: red "stripe", 1.46" dia., GN1 heads tminer General Turbo Buick Tech 2 May 25th, 2004 06:33 PM
"Turbo Six Tuner" versus "Tunercat" chip tuning software... Irid Computer Chips 101 8 August 14th, 2002 12:26 AM
