Old October 27th, 2006, 01:35 PM
206/210 Roller Cam Kit - Comments
For my setup Mike @ Fullthrottle recommends his 206/210 roller cam kit. Any comments on running this cam with a stock turbo, 42.5 lb injectors, THDP, RJC intake plate, Ross forged pistons and also my heads been ported other wise pretty much stock.
My "old" ATR cam was a 206/206 and worked very well with my setup.
Would I need a new custom chip? And I'm running a 2500 stall converter at the moment.
Good or bad things running the 206/210 roller (this is the Comp Cam extreme one with comp roller lifters and then beehive springs) ...
Old October 29th, 2006, 02:52 PM
Anyone ? I need to order all the stuff this week so any comments / suggestions would be appreciated
Old October 29th, 2006, 07:24 PM
TT/Ameasap's Avatar
Trader Rating: (8)
Just stay away from a budget roller cam
89 TTA with built 109 .040 over J&E pistons,K1 rods,billet steel caps,steel crank,224/224 flat tappet comp cam,HV front cover,port matched intake,fully ported TTA heads,PT70 turbo,KM sheet metal intake,50# injectors,billet fuel rails,TT chip,NX nitrous wet shot system,3'' THDP,SM2,Razors alky injection,vigilante 3200 stall,fully built tranny,drag bags,convo pro wheels,15x9x30 Hoosier slicks in back with 15x3.5x28 skinnies up front. 6pt cage for now.
Coming soon to a strip near YOU!
Old October 29th, 2006, 09:14 PM
AKTURBOTA's Avatar
I am going with a 210/215 for the 4.1 that is going in my TTA. I have heard many good things regarding this Comp Cam that is offered by Full Throttle. One downside that I have heard, but not many comments to that effect, is that since this particular series of cam is a very aggressive profile, that it could be noisier than stock. The good reports outweigh the minimal negative comments. If I were you, I think that you are making a good choice...especially since you are buying the entire cam and kit.
Mark
1989 Turbo Trans Am #178, "291" 4.1 with ported irons and intake, rollerized valve train, 210/215 roller cam, PTS 9/11 3200 T/C, CPT66 BB, stock IC with Duttwieller neck in the works.
Previous combo: 11.79 @ 114.7 w/1.61 60' all time best with TA49. ATR bleed valve to control boost, Ext Chip - 23/19 timing, Translator Plus, LT1 MAF Sensor, 62mm T/B, ported plenum, 1" plenum spacer, 60# MotoTron injectors, Adj F/P reg, Walbro 340 F/P, Action Fab 3” D/P, freeflowing exhaust with testpipe, 110# valve springs, PTS 9/11 Lock-up 2800 T/C, BFG Drag Radials on stock rims, Spohn Adjustable Torque Arm, Global West Subframe Connectors, Spohn Adj Panhard Rod, Spohn Lower Control Arms
Old October 29th, 2006, 09:27 PM
Buick "RICER"
Trader Rating: (14)
how about just a 206/206 roller ??? you goin to race the car ??? how fast you lookin to go ??
Dan
Old October 30th, 2006, 06:39 AM
Razor's Avatar
Forum tech Advisor
Jan,
I ran the 212/212 one from Comp in my other motor and no issues. Use the 853 lifters.
HTH
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old October 30th, 2006, 01:45 PM
2QUICK2B6's Avatar
Black Car Fever
Im going with a 212/212 in my TTA engine should be runing in a month or 2
89 TTA#299 STOCK 34,000 MILES * Vanna White *
89 TTA#1397 small turbo and acouple bolton's
87 GN Black Plague TE60 / Stock Long block with the regular BOLT ON'S 1.552 60ft on M/T DR 275/50/15 @ the Rockingham buick meet
and acouple slow v8's
http://i92.photobucket.com/albums/l6...Picture367.jpg
http://i92.photobucket.com/albums/l6...Picture443.jpg
