Go Back   TurboBuick.Com > Tech Arena > Turbo's and turbo related parts
Old August 3rd, 2008, 06:18 PM
turbo blue 3.8's Avatar
Asphalt Cowboy
Question BOV vs. Wastegate
Alright I've got a question: I'm goin' to have to buy a new turbo and I want to purchase a BOV with it . But I'm lookin' for some of the pro's and con's of BOV's and Wastegates and which would be better to put in my street/strip HA 84 GN. Any help would be appriciated. Thanks. Also any new turbo advice would be nice I'm lookin' to buy a BB unit preferably from turbonetics : good choice or bad choice?
Old August 3rd, 2008, 07:06 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
They do different things and most GN owner don't have either.
If you are worried about compressor surge at WOT then get the BOV.
The GN's have good internal wastegates so unless you're running a large turbo or want a really low amount of boost then leave that alone.
Mike
87GN T-Top down 423lbs.
Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Billet Drum/Input, PI 3400 5disc, T Brake, Inland 3.5" DS, KB Plenum/70mm TB, Razor's Post Turbo Alky Kit, Devils Preturbo Alky Kit, TT Chip, 60lb Inj, Denso 280 Pump,-8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, ATR SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, QA1 Shocks, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs
Old August 4th, 2008, 05:54 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
Got a PM about my post so I need to clarify.
If you are worried about surge AFTER WOT then get the BOV.
Mike
Old October 21st, 2008, 08:42 PM
Asphalt Cowboy
Is compressor suge after WOT a big problem with these cars? I've heard that there is really no need for a BOV with and automatic transmission.
Old October 21st, 2008, 10:14 PM
Camfreek's Avatar
Thanks Rob!!!
I know I am going to hear about this!
If I had understood correctly?? A waste gate controls the exhaust part of the turbo and bleeds it off to maintian a certain amount of boost? Kind of like the acctuator does, but usually for bigger turbos.
As far as the BOV, you are right about not really needing one for an automatic car.
I have a 1990 Ford Ranger and it has a 5 speed trans in it. I had a hard time keeping the turbo spooled up in it. Every time I changed gears the turbo would spool down and I would have lag all the time. I put a blow off valve in it to stop the surge.
Every time I change gears now it blows off the excess boost when the throttle plate closes.
Unlike most people I do not just let mine blow off into the engine compartment to sound cool. I have mine set up so when it blows off it goes into the intake right before the turbo Keeps the boost up where I like it.
I don't know if that helps you understand the differance at all?
I realize a bad drug habit would be cheaper but not as much fun
84 GN Mease down pipe, Cold air intake, Edlebrock double roller and valve srpings, Accel FPR, Arp studs through out, other stuff I forgot
84 WH1 down for repairs all stock except cold air intake, Bosch 237 FPR
84 T type parts car with a posi and t tops
88 Trans Am built 400 short block Lunati rotating assy. 327 Double humped heads, Pete Jackson gear drive, TPI setup, All blacked out
86 Full Size ford Bronco, 35" mudders, lockers, 302 HO short block, GT40 heads, Hooker headers, True dual exhaust, MSD ignition, 92 LSC ECM, Pulls the fronts off the ground
75 VW Beetle need I say more
93 Camaro God I hope it is sold soon!!!
90 Ford Ranger 2.3 turbo and my daily driver
Old October 23rd, 2008, 12:17 AM
Red C5's Avatar
I have an external wastegate on mine but no BOV.
How big of a turbo you looking to go? I'm going to sell a GT4276 never used but it's probably way too much turbo for you.
Check Out My Aluminum Radiator For Sale
1987 GN
10.60 @ 130
Old October 27th, 2008, 09:21 PM
Asphalt Cowboy
Yeah mine's not a dedicated drag car it's a street/strip car looking more fer like a small turbonetics BB turbo but thanks any way. I mainly wanted to know...I guess if a BOV would help my car at all be it by makeing it last longer or in the performance department. The wastegate was more or less a wet dream fer me, at least for now.....
atr wastegate brutalv6 Turbo's and turbo related parts 8 June 2nd, 2005 08:00 PM
Looking for a wastegate 86BLACKT Parts wanted 1 April 5th, 2005 04:04 PM
External Wastegate versus Internal Wastegate? Maltman Turbo's and turbo related parts 8 July 30th, 2004 12:19 PM
Wastegate? Whitettype86 General Turbo Buick Tech 0 January 18th, 2004 11:06 AM
Which one controls the boost, wastegate solenoid or wastegate actuator? 1of1547 General Turbo Buick Tech 7 August 31st, 2003 01:11 PM
