LinkBack (5) | Thread Tools | Display Modes |
88 Turbo on a 109 block 136 mph 9.97
Well this weekend at Turbo Thunder Ryan Guy got his 88 on a iron headed FULL weight car to run
9.97 @ 136mph He uses the blue bottle to get it to spool but he still has a 109 block and i believe stock main caps What i cant believe is the temp was close to 100 deg and (2600 ft) im sure his 60 ft was bad like all of us That block and crank is the same one,s he has be beating for years.. That block took some real HP this weekend to do that and lived![]()
http://www.turbobuick.com/forums/pac...-update-6.html Gene Fleury 86 Green GN Off Center Stage 2 (9 sec 140MPH street car 17 MPG) POS Buick With Stage 2 on center(Looking for high 7,s) In work 67 Chevelle Convert 283 PG Last edited by geno : July 1st, 2003 at 01:15 PM. |
He told me it was 33 or 34 plus
http://www.turbobuick.com/forums/pac...-update-6.html Gene Fleury 86 Green GN Off Center Stage 2 (9 sec 140MPH street car 17 MPG) POS Buick With Stage 2 on center(Looking for high 7,s) In work 67 Chevelle Convert 283 PG |
Oh
Did i mention stock axles and rearend ![]()
Are you serouis? stock axles..holly crap
that's crazyWhat where the 60ft's? Is this a aluminum headed car?
Chris McDade 87 GN Stock Block, heads, cam, Turbonetics BB 66 S-trim .63 Housing, PTE stock location IC, 3.5" THDP, 2-1/2 hooker exhuast, Built Tranny, Art Carr N/L 9", adj regulator, Double pumper, 72's, BMR lower C arm's, Max effort, GNX Wheels, no times yet. 87 GN (Dad's Car) Build 109 with all the goodies Update 10/31/08*****10.78@125 Getting there! 87 T 10.44@129.85 1.47 60ft (Sold) |
A local guy here had talked about running one on a stock based block. An "88" turbo is a monster and on Stage 2's they are propelling them to 165mph+........
Ryan is one crazy guy to be running one.... If memory serves me right when I talked to Terry Ryan about a year ago that the engine has billet center caps, stock GN crank/rods and TRW's with JE pins. The heads are iron and so ported that they had to use epoxy to fill up some of the thin areas and valves larger than 1.77 for the intake. ALso the combustion chambers were reshaped as well slightly to accomodate the larger intake valve. The intake runners have had aluminum welded on top where the injectors are to straighten out the airflow path. Many many hours of labor into that setup. Same engine that went 9.99@135.99 mph with a TE-76 turbo and 30psi+. Geno- was he running the stock ECM last time I heard still with 7th and 8th injectors and (6) 55lbers.... or is he running a FAST/DFI fuel management now? -GNX7
'87 Mazda RX-7 with '87 GN drivetrain stk turbo/convertor 11.62@114mph R.I.P. http://www.wrongmotor.com/gallery/mark_c/index.htm. LS1/T56/RX-7 FD 13" AP brakes, coilovers, 18x10.5 CCW's. 439rwhp/385rwtq 2800lbs/1.13g's 11.42@127.4mph n/a SOLD http://www.turbobuick.com/forums/sho...d.php?t=195038. LS7/T56 RX-7 FD project: 575rwhp + 140mph trap speed n/a goal |
He has a Felpro now
I know him and Terry have alot of work in those heads but i didnt think he had steel caps I do know when Terry ran 10.2 in his car it had stock caps Those guys like to take the stock parts to and past the limit![]()
I dont see anything wrong with running an 88 turbo.
1997 Toyota Supra - 3.4L Stroker, GReddy T-88H, HKS FMIC (too much more to list) 9.7@153mph 2002 Pontiac Trans-AM WS-6 (Show Car) hoping for 150dB+ |
87 Turbo-T, bolt-ons.... |
(GNX7 Wrote)
If memory serves me right when I talked to Terry Ryan about a year ago that the engine has billet center caps, stock GN crank/rods and TRW's with JE pins. Your memory is right on gnx7 Ryan does run steel center caps and ARP bolts for the rods and mains I just got off the phone with Terry and we are going to meet up at Portland this weekend for the night street legals. It should be fun to mess with some people![]()
damn! 30 years old and my memory still works
.....Wish it archived more relevant info than just car stuff. I'm curious how fast that "88" will go in his full weight car. I'm sure it could go 9.60-.70's.... if he went 9.96 in 90-100* weather. Ryan Guy has some major kahones to turn the wick up on that turbo, spray NOS, and run the factory "109" block/crank/rods...... I'm going to be cautious turning up the wick on my "70" as I want this engine to last a few seasons if possible and mucho street driving. -GNX7
87 Turbo-T, bolt-ons.... Last edited by 86brick : July 1st, 2003 at 10:44 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/turbo-lounge/89359-88-turbo-109-block.html
| TSM leader board times - Page 5 - t6p.com - Turbo Buick Regal Resource | This thread | Refback | June 17th, 2007 11:11 AM | |
| TSM leader board times - Page 5 - t6p.com - Turbo Buick Regal Resource | This thread | Refback | June 6th, 2007 11:01 AM | |
| TSM leader board times - Page 5 - t6p.com - Turbo Buick Regal Resource | This thread | Refback | June 5th, 2007 05:17 AM | |
| TSM leader board times - Page 5 - t6p.com - Turbo Buick Regal Resource | This thread | Refback | June 4th, 2007 08:41 PM | |
| TSM leader board times - Page 5 - t6p.com - Turbo Buick Regal Resource | This thread | Refback | June 4th, 2007 08:30 PM | |
