1997 Blazer Radio Removal
I want to remove the stock radio on an '97 Blazer so I replace it, but I'm not quite sure how to get it out without wrecking anything. I'd appreciate it if someone could tell me how to do this or where I can find out.
Thanks!
1984 Grand National Body and Interior restored to be driven Motor stock...mods to come |
I have a 96 s10 and to remove the radio first you have to remove the dash bezel then you will see the screws holding the radio.
86 GN T66DBB , 60lb injectors Turbotweak chip alkycontrol kit ,PTE Front mount,Translator +,KB 70mm TB, RJC power plate , KB adj fuel reg ,THDP, ATR Headers GNX dash H&R mounts, CK Perf trans 3200 single disc Vig converter 87 Turbo T Stock except for hooker cb, mp 3 Dp ,36lb inj & Dutt neck "Horsepower is how fast you hit the wall, torque is how much of the wall you take with you." www.ckperformance.com www.westcoast6s.com |
there are a total of 4 screws holding it. Two of them are on each side of the steering column the other pair are by the dash cluster
The rest is held by clips and pulls out. .. Drawings not too good .. Top of dashboard ---------|-----------#-----------------#----------| -------- | | | | Dash cluster |
86 GN T66DBB , 60lb injectors Turbotweak chip alkycontrol kit ,PTE Front mount,Translator +,KB 70mm TB, RJC power plate , KB adj fuel reg ,THDP, ATR Headers GNX dash H&R mounts, CK Perf trans 3200 single disc Vig converter 87 Turbo T Stock except for hooker cb, mp 3 Dp ,36lb inj & Dutt neck "Horsepower is how fast you hit the wall, torque is how much of the wall you take with you." www.ckperformance.com www.westcoast6s.com Last edited by petesgn : April 10th, 2003 at 09:36 PM. |
